Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Soru Tümünü görüntüle
Very slow 802.11n airport conection and lack of range
I replaced the airport card in my A1811 MacBook with a MacBook Pro several years ago and have not had the range or especially speed tha t was expected - virtually no improvement over the orginal card. The card is supposedly Apple # MA688Z/B. Is there firmware/ software or an antenna wiring problem. Is this the same card that you are selling for the update the Core Duo?
Bu iyi bir soru mu?
Puan -1
1 Yorum
I have susequently reversed the antenna wires at the (802.11n) airport card within the MacBook and now have satisfactory speed at 60+ feet.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you update the base station also? You won't see n speeds without an n base station. Ralph
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
maybe its not your computer but the wifi base stations you connect to?
or something upstream?
your antenna could be part od the problem too.
this is a brad question - can only elicit a general answer
Puan 1
Yorum Ekle
I have updated the base station - airport extreme to the latest software / firmware. I feel it is related to the antenna as the closer I get to the base station the faster it gets. When I am over 30 feet it is very slow. My new MacBook works very well this distance. Could I have hooked the antenna wires up backwards or do I need different antennas?
Puan 0
1 Yorum:
your ld antenna may not be working well with the frequencies used in 'n'
IIRC we have 2 bands of frequency used in WiFi - so your suspicion could be correct
tarafından
Yorum Ekle
Yanıtını ekle
minicoopers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,901
