Ana içeriğe geç
1.5 Core Solo, 1.66 veya 1.83 Core Duo ya da 1.83 veya 2 GHz Core 2 Duo işlemci. Bu sayfa, 2006'nın başından 2007'nin ortasına kadar üretilen ilk Intel tabanlı Mac Mini modellerini kapsamaktadır.
No Sound from Mac Mini!
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
En Yararlı Yanıt
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Mac mini Model A1176 Ses Kartı Değişimi) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
Puan 5
1 Yorum:
this was it for me, SSD was installed by previous owner and the ZIF cable was re-seated BEHIND the actual connecter! Phew :)
tarafından Paylaş
Yorum Ekle
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
Puan 2
Yorum Ekle
Thanks Gary, this was exactly it!
Puan 1
Yorum Ekle
Yanıtını ekle
Robert Antoine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 12,329
