Broken Headphone tip stuck inside PS vita
So my headphone jack broke inside my ps vita, i have tried getting it out with a pair of pliers and small objects to no luck. should I go about opening it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The headphone jack is connected directly to the motherboard, and there is no way to remove it without soldering (reference: here and here)
I've read that getting a very small drill bit (#76) and applying some slight side pressure and flicking out may work.
I've also personally had limited success (read: one time) of very carefully and VERY gingerly drilling out the middle of a broken-off headphone jack with a tiny drill bit, then extracting with dentist tools. I'm not suggesting this as the BEST course of action, but it is possible. If you attempt, make sure you have a way to secure things so they don't move about when you're drilling. (A vise with soft pads perhaps) and be careful.
Cheers!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 654
