does not start . how to check why
does not start. what to check to see why
Bu iyi bir soru mu?
Bu iyi bir soru mu?
David,
More info would help to point you in the right direction.
Basically you need Ignition, Compression and Fuel
Compression- Is engine turning over or cranking (battery, connections, starter, relay)
Fuel- Are you getting gas to cylinders (fuel, fuel pump,injectors and sensors)
Ignition- Spark to to cylinders (spark plugs, ignition coil, plug wires and sensors)
Hope this gives you a direction, Glenn
David,
Check this out
https://wiki.bentleypublishers.com/pages...
Glenn
Bu yanıt yardımcı oldu mu?
hi Glen > this will be my first time working on one of these cars . No problem turning it over . If there is spark then start at the fuel . What pressure should the fuel be
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 968
