Ana içeriğe geç
The Lenovo G570 is a 15-inch laptop announced in January 2011.
23 Soru Tümünü görüntüle
Some horiontal line is displaying in my laptop
I thought the reason might be due to loose connection to my laptop display. I tried to press my screen at corners but it does not works for me :( . So could you please tell what is the solution for this...
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Horizontal lines are often LCD display problems with the driver chips and/or the screen got a hit on the edge breaking the fragile connections to the driver chips.
In any case the panel assembly will likely need to be replaced. You can verify this by connecting to an external display if the external display image is not distorted then you know its the LCD display.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hi,
Try reinstalling the drivers for your VGA if that did not solve the issue you have to replace your LCD. You can search and buy for your laptop model LCD from eBay.
Good Luck.
Puan 1
Yorum Ekle
Yanıtını ekle
Anjani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 17,112
