Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
Black screen after battery and screen replaced?
Water damaged I pod touch 4th gen,I've replaced the battery and screen,iTunes recognizes the i touch but screen still will not come on. I've tried shorting the battery(and heard the "peep",like when you connect your i touch to a charging cord) and I can see all the contents of the i touch on iTunes. The screen is good,I tried it on another 4th gen i touch before installing it. I've cleaned the connectors and tried re-connecting several times,tried letting the battery go dead and then re-charging to see the screen(this worked for another i touch screen I replaced). I'm not sure what part to replace on the logic board for water damage. I've also cleaned the logic board thoroughly with isopropyl.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You are already tried everything that can be recommended and if the battery and screen both are working fine on other iTouch then seems like there problem is only with motherboard. I shall recommend you to check the display connectors with some magnifying glass to make sure that each bit is properly connected. Just in case you can it take it to some hardware shop for a last try or otherwise you may have to replace the logic board.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 89
