Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Sticking track pad button
is this trick valid for Macbook Unibody (white) too? Reference to this question Trackpad click button is jammed
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I don't recommend the WD-40 trick as it will only make a mess. The oil in it will act like a magnet collecting the dust and debris around your system.
While its some work you can take the track pad out and clean it properly and make sure it's OK (and if needed carefully lube the pivot-point).
The root issue is something either is jamming it or something was spilled onto the click button.
Lastly, the battery could have swelled-up pushing on the trackpad from below.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
visoyah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 221
