SUD warning during wash
the Normal cycle begins fine, but am seeing "SUD" on the (time remaining) screen during the wash ... please note I am using the same Tide Pods detergent as always.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Mike, according to the service manual there are a few possibilities
Sud - SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Best answer yet and I’ve been doing this since day one figured it out on my own but wanted to make sure that I wasn’t doing something wrong thanks for the good tip
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 45
Her zaman: 17,889
