Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Soru Kapandı
Audio jack suddenly stopped emitting sound.
When I plug a headphone in the audio jack of my Macbook Unibody White A1342 I notice that the system recognizes it by stop using the speakers and raising the volume but I hear no sound.
There's no red light coming out of the jack and I started suddenly with no liquid spills or other accident.
Any hints on how to troubleshoot this?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the headphones in another device. If they don't work their either they are suspect. Some are worth repair, some are not (you'd need soldering tools and time).
If they work in another device follow some of the tags at right for some troubleshooting repair steps for your Macbook. A workaournd if the port is damaged (you can't repair them) is a USB audio adaptor. USB audio is separate from analog/digital audio.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Yes the headphones do work on other devices. There's only one answer that's similar but it did not solve the problem.
tarafından
I'd try the workaround... it's a good, cheap and easy fix.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 266
