Ana içeriğe geç
The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
11 Soru Tümünü görüntüle
Soru Kapandı
Bass does not work and not works periodically. battery holder
I had my headphones for a year. All of a sudden, the bass goes on and off. I opened the battery compartment and sometimes when i listen and press the battery towards the minus, the bass comes back on. Is there a way to adjust the metal to have the bass on? And my battery works too.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Patrick Chan,your negative post is a simple spring, and you could just pull it to elongated it. Do make sure that this is the problem, check the ground connection on your board as well as the solder connection to the wire.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 3,244
