Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Soru Tümünü görüntüle
Is it possible to install two 3.5" drives in 2007 iMac?
I've been doing some research about replacing the optical drive with my current hdd and adding an ssd to the original hd slot.
So far I have found that adapters for the optical drive only accept 2.5" drives. Both of the drives I want to use are 3.5". Is it possible to fit 3.5" drives in the hd slot and optical drive bay? If so, do I need a special part to adapt the optical drive to the hdd?
Many thanks!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
NO - the space available is for a 2.5 drive there isnt' an extra inch to be found. study the guide for HD replacement... I have not found a 2008 3.5 optical drive kit for an iMac. If you have one that may be possible there's more room.
I suggest you find the optibay kit first, then the drive that fits it.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
lanceakiyama sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 207
