Ana içeriğe geç
Samsung Epic 4G, Samsung Galaxy S Serisi'nin Sprint modelidir.
Charge port fire hot
Phone will not turn on. Battery is fine. I have it down to board level. Plugged in to charger and within seconds charge port itself is fire hot and smells like burnt plastic.
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
check for shorting on plug? is it an OEM plug? pin alignment proper? an OEM charger? what were the symptoms before it went dark? check for heat damage from the possible shorting at the plug and the board, if it has gotten that hot it may have re-soldered its own connections
together- check for any abnormal solder flow anywhere near the heat source.
is the pwr button stuck in the depressed pos?
these are just off the top of the ole noggen, good luck. and remember to use your heat-sinks.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
GADGET DR sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 485
