Ana içeriğe geç
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
ipad bad lcd
Hi, I just replaced my ipad 3rd genertaion's lcd. I replaced it because i thought that it had gone bad after the screen turned blue. After replacing the lcd nothing changed the screen is still blue. If anyone knows what the problem is and what part is needed I would be very gratefull. Thanks
I just took it to a repair store and they said it was not the lcd and it was not the logic bord. i was wondering if it was the little connector that you put the lcd cable in to, if it is how to fix.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
it can be caused by a strange software glitch, but its really unlikely. all you can do to eliminate this is to reformat it... other than that, there is only the LCD or the Logic Board that could cause such a fault. The LCD in the iPad 3 doesn't have a separate LVDS cable, as it connects directly to the Logic Board through its integrated cable, so i don't see how the repair company could have eliminated the Logic Board as a possible cause without having fitted a replacement LCD and found it to be working.
Is it possible that your replacement LCD is not a good quality one? are the faults on the original and replacement exactly the same?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
tristan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 420
