Ana içeriğe geç
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Soru Tümünü görüntüle
Soru Kapandı
How will iMac react if optical drive and fan are removed?
Hello,
I already post a question regarding "noiseless imac" due to my hyeracusis disease.
My iMac is now open (glass and display removed) and the goal is to replace the HDD by a SSD.
I had a look at components location and wondered what will happen if I also fully remove the optical drive AND the fan under. Except possible evident temperature issue and risks, could you please let me know if the system will halt if the drive and the fan are disconnected from the mainboard ?
Thank you,
David
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would not remove the fan, unless you have some quiet alternative to pass cool air through the machine that fan and sensors work together to keep your CPU from cooking (overheat damage.. like the head on a car engine… you couldn't run a normal water-cooled engine with out the radiator fan.) .
I think the machine will boot. If (when) it overheats it should shut down, but that's not a good thing. You will eventually kill the drive, and the CPU.
Removing the optical drive should cause no problems booting or running… it' done all the time.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 200
