Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
Black screen after replacement
I just replaced cell signal antenna and the power-button/sensor cord and I adjusted the home button, cause it was too tight.
After I was done and put it all together, the screen was white on one half of the screen and black on the other half, after 10 seconds the white faded away and it all got black.
I then turned it off by holding home and power button, then I whiped the LCD and digitizer connectors with a piece of paper, I also replugged the battery connector just to be sure.
When I reassembled it again, the screen wouldn't even turn on at all. To make sure it actually was on, I Connected it to the PC, it turned out to be on, but the phone speaker itself made an beep noise every 5 seconds while Connected to the PC.
What has happened?
Update:
I cleaned the connectors again with Windex on a Q-Tip.
Now it's just back to black screen, but atleast it's on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You may have damaged the LCD cable of your screen. did you try another screen?
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Can I try another screen without the replacement procedure, just attach the cables?
tarafından
Yorum Ekle
Yanıtını ekle
Mats sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 512
