Only Hynix RAM compatible with iMac 21" late 2013?
There're two Hynix RAMs in iMac 21 inch late 2013.
I tried to replace Adata, Kingston, Apotop, TEAM RAMs with Hynix RAMs, but is not working.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Standard RAM: 8 GB Maximum RAM: 16 GB*
RAM Type: PC3-12800 DDR3* Min. RAM Speed: 1600 MHz
Details: *By default, this system has 8 GB of 1600 MHz DDR3 SDRAM. Apple does not intend for one to upgrade the RAM in this system. However, as first reported by OWC, this system has two SO-DIMM slots (204-pin). Unfortunately, accessing these slots requires one to pry off the display that is glued to the case and remove the logic board.
Scroll down to get to the installation video on this link: http://everymac.com/systems/apple/imac/i...
Bu yanıt yardımcı oldu mu?
I have replaced the original ram with Corsair modules 2x8gb. No problems encountered.
Recently I have purchased two SK Hynix 8gb ram to upgrade my Imac 2013. I want to know whether it will compatible. If you can please provide me some info regarding on this.. Thank you.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,975
1 Yorum
I installed G.Skill 2x8 gb DDR3 1600mhrz and I cant get the darn thing to work. Keep getting a beep when I try to boot it up. round 2 for me help
m.neal67 tarafından
