Ana içeriğe geç
I need the car radio code
Hi I change my battery on my Honda 2004 Odyssey. I need the car radio code. The radio serial number is [serial number removed for privacy]. and the vin number is [VIN removed for privacy] Thank you. My email is [email removed for privacy]
Bu iyi bir soru mu?
Puan 5
2 Yorum
I did the same thing my serial number is 2417 my vin is 1hgem22963l00904 my email is corley937@gmail.com
tarafından Paylaş
Hey Gregory, you can actually get a radio code here: https://radiocodevault.com/honda
Hope it helps mate
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
skyppy103, look on the side of the glove box or behind the ash tray for a sticker with a 5 digit code .If its not there then you will need to remove the radio to get the serial number and either call your Honda Dealer for a new number or post it back. If it is a 2002 or newer try this
Turn your radio off.
Turn key to the ON position. Do not start, just leave ignition in ON position.
Press and hold the numbers 1 and 6 on your radio with one hand.
Using your other hand, turn the radio on while keeping 1 and 6 pressed.
Ten characters will appear on the screen, usually alphanumeric. Write down all the numbers you see.
Now you can either drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. Or you might want to try this one online. https://radio-navicode.honda.com/
Bu yanıt yardımcı oldu mu?
Puan 5
4 Yorum:
Worked!! Thanks oh it was in the glove box
tarafından Paylaş
Hi i changed my battery in my car and i now needs the code to my radio i have a 1999 honda accord my serial number is m98k103374
tarafından Paylaş
Hola,antes que nada buenas tardes, yo compre una Honda odyssey 2003,el problema es que el estéreo está bloqueado y las personas que me la vendieron no saben el código la realidad es que nose que hacer,gracias
tarafından Paylaş
i nded my radio code for a honda accord 2003
tarafından Paylaş
Yorum Ekle
You can find the radio code for your specific car here: https://radiocodevault.com/honda/
They worked for me, and emailed me my radio code in 30 minutes. Should work for you too.
Puan 3
2 Yorum:
WORKED thank you a lot!
tarafından Paylaş
thanku this worked for me
tarafından Paylaş
Yorum Ekle
Hi,
I would highly recommened that you visit FreeRadioUnlocking.com
You can find their guide on generating a Honda Odyssey radio code for free here: http://www.freeradiounlocking.com/brands...
I can personally vouch for this website as I've used it to unlock the radio of both my Honda Civic and my wifes Honda Accord and it worked great both times.
I hope this answer helps you out!
Puan 1
1 Yorum:
Does not work!..... Just a bunch of ads :/
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
skyppy103 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 90
Her zaman: 34,457
