Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Uncooperative Home Button
My home button does not respond like it once used to. Often, or I should say usually I have to press it more than once to get it to respond or press harder than I'd like.
Can it be replaced by itself and/or will that fix the problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
No this iPhone 3G has never been taken apart nor is the problem that severe that I'd spend $150 on it. It is annoying enough to want to open it to replace let's say a $50 part or less.
The most frustrating part is sometimes the home button works fine but you never know when so sometimes you have to press hard or hard and long and sometimes a normal press will work.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It should definitely fix the problem.
Here it is, and here's the Guide
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Has this iPhone been taken apart before? Due to the way the home button in the 3G[S] model is built, contact between the button and its conductive strip is only achieved through the screen portion being reseated perfectly. It could be that a piece of junk has gotten wedged in between the contact and the button- I would check that before you buy any new parts.
Puan 0
Yorum Ekle
just go settings/general/passcode lock and enable passcode lock. now look
Puan 0
Yorum Ekle
I had this issue before with iPhone 3GS and 4. One very simple solution before you think about replacing any part is the following:
You'll need
- acetone
- cotton ear bud
Procedure: use the ear bud to drop 2 drops of acetone in the home button of your iPhone. Immediately, use the same ear bud to press the button down quickly around 20-30 times.
You' then probably notice the button sensibility appearing again.
This is due to the grease from your own fingers starting to accumulate in the button sensor. The acetone will help to dilute that grease.
Puan 0
Yorum Ekle
Yanıtını ekle
velvetpunch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 12,376
