Ana içeriğe geç
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 Soru Tümünü görüntüle
reconnecting touchscreen cable after batt. replacement
When reconnecting touchsreen cable after battery replacement should I push connector straight down ? I gently tried twice and it didn't connect.
The jack or plug is not broken, should I use a little bit more force? The battery cable 'snapped' in just fine.
Bu iyi bir soru mu?
Puan -1
1 Yorum
Your advice worked. Then when I tried to power on it wouldn't. The reason for un hooking was to disconnect battery & seperate so it could dry. It fell victim to a 1.5 sec total immersion in clean water. I left it seperated for 8 days to dry. As of this post it is currently on charge. Fingers crossed for next power on attempt !!! You were correct about "just a little more force" to connect, Thanks for your timely response.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Push it down with a bit of force, as long as you are sure that they are properly aligned. You should feel a little bit of snapping, then the connector is connected
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Roland Deschaine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 137
