Ana içeriğe geç
Bose QuietComfort 2 akustik gürültü engelleme özelliğine sahip kulaklıklar için onarım bilgileri. 2003 yılında piyasaya sürüldü. Model numarası: QC2.
How to fix when battery corroded
Battery corroded in my Bose Quietcomfort 2 and now they won't work. Called Bose, no help. Attempted to clean the connectors, still won't work. Any suggestions, please help!!!
Bu iyi bir soru mu?
Puan 6
2 Yorum
This recommendation absolutely worked for me. You must try this before you take more invasive measures.
tarafından
The vinegar worked for me. Ive had my Bose headset quite a while and didn’t want to part with it. I cleaned with the vinegar initially a week ago without success. Tried it just now and bam—green light. Thank you.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
My favorite method to fix this is using a q-tip with baking soda and water. I usually just moisten the q-tip and then dip it in the baking soda then i scrub away the battery acid.
Bu yanıt yardımcı oldu mu?
Puan 7
5 Yorum:
I'm sorry. What is a q-tip with baking soda and water? Thanks!
tarafından
Thank You. I tried the alcohol Q-tips and it cleaned the mess but no contact was made. I used the Q-tip with baking soda and it worked .
tarafından
It worked. Thank you
tarafından
q-tip and white vinegar worked for me.
tarafından
I also used the Q-tip with baking soda and it worked. Thanks for posting this!
tarafından
Yorum Ekle
En Yararlı Yanıt
Vinegar is supposed to remove alkaline battery corrosion. I used a q-tip and vinegar to restore my Bose QC2s, and then was careful to never store them with the battery inside. Unfortunately, despite this, they developed the same problem again (not turning on when a good battery is inserted), and this time vinegar has not been able to make them work.
I can barely see inside, but the anode at the bottom ("-" side) looks corroded brown rather than green. Perhaps a different issue. I can't believe how fragile these super expensive headphones have been. I'll try more drastic measures to clean inside there...not much to lose at this point.
Puan 8
11 Yorum:
it worked !! the Qtip submerged in vinegar worked. clean the battery compartment real good! Thank you thank you. I was going to return my headset but now I am going to keep it.
tarafından
The light should turn Green..on QC 15
tarafından
This worked for me- Bose headphones fixed. Thanks so much!!
tarafından
Worked for me as well. thank you very much
tarafından
this worked for me, after cleaning; insert a battery and if doesnt turn on give the headphone a little tap a few times it should turn on.
tarafından
6 tane daha yorum göster
Yorum Ekle
Hi dcar,
I would suggest to use fine sand paper and use it on the corroded metal battery holder part until you get it to look like metal again. Then use alcohol of some sort to clean it off. To avoid getting dust inside tape off any holes from battery compartment to the product before sanding.
best of luck.
Puan 1
Yorum Ekle
Yanıtını ekle
dcar2004 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 27,342
