How can I fix for my furby does not speak?
My Furby doesn't not speak and only does the movement.
I thought that it is because of low battery.
Then I changed with new batteries.
But it still doesn't speak.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
sara, I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
I tried that and it won't work still, what should I do?I also don't want to remove the furry booms skin
My old furby doesn't work it has no voice only makeing gear sounds he works fine but thats his only problem i took him apart but dont know how to fix the problem
Hi.
Did you manage to find a fix?
Dame problem here
To repair this you may have to replace the speaker. 2 ways to get one is find a speaker online or buy a parts furby to take the speaker from. One one thing I'd advise against the parts furbies is that most of them actually work but the gears are stuck and to fix them you got to bang the bottom of them super hard against your palm for awhile.
If you have installed fresh batteries, and Furby still won't talk, push the reset button and the tongue at the same time when the Furby is turned on.To turn on the Furby, turn it completely upside down and back upright again.
It weren't help full it carried on silent help what shall I do ?
I had the same problem but mine had some noise and it was a normal furby.I changed the batterys and held recet for 20 seconds
Where's the reset button ?
I change the speaker with a new one. It works for me.
Where did you get a new speaker,
I got a new speaker from ebay I think but the voice still isn't working, I'm working on trying to test the board but I'm not well-versed in that
Where can I purchase a Furby speaker?
You'll need a donor furby, you can find some cheap ones online that are being sold for parts
I use this part:
https://www.amazon.de/gp/product/B00UJ99...
The original one is a litle bit louder!
My.furby is talking but the volume is very low..I can barely hear it..what can I do
Son 24 Saat: 10
Son 7 gün: 73
Son 30 gün: 307
Her zaman: 36,728
8 Yorum
Having same problem! What can we do?
Carlos Ortega tarafından
Well i kinda have a similar problem only my boom speaks... but also the speaker makes this crackeling noise too. I replaced the speaker but firby still crackeling...out of ideas, what should i do???
Mimi B tarafından
My fur by will talk but u wouldn't be able to hear the voice what so ever I've tried every thing but it won't work what shall I do
Amanda tarafından
Is there a place that repairs Furby?
Mable Bartlett tarafından
Today I ordered a new speaker for my sons furby boom. It should be 16Ohms, but my meter shows me 4MOhms :(... I hope, after changing the speaker all is well again...
toniweber tarafından
3 tane daha yorum göster
