No backlight after display assembly replacement
Hi, can I get some help in finding the schematics and the Led driver on my MacBook Air ? The fuse is good but still no backlight on the device. The whole display assembly is replaced.
S/n C02J52DEDRVG
Best regards,
Vlad
Update
Hi oldturkey03,
I really appreciate your effort in helping out a stranger.
The MacBook air was declared dead after a liquid spill and out of warranty. Now the MacBook works on an external display. After reading a bit on the net, I found the fuse which is marked with a "P" and if I measure it with an volt meter and set it to conductivity (diode sound measurement) it says that the fuse is ok. I'll try to attach the images from the MB and I would be grateful if you can help me find out the led driver location and the filter location.
Thanks in advance,
Vlado
Update
Here is the
Update
Bu iyi bir soru mu?
5 Yorum
2.0 GHz Core i7 (I7-3667U)
Intro Date: June 11, 2012 Disc Date: June 10, 2013
Order No: BTO/CTO Model No: A1466 (EMC 2559)
Subfamily: Mid-2012 Model ID: MacBookAir5,2
Std RAM: 4 GB Std VRAM: 384 MB*
Std Storage: 256 GB SSD Std Optical: None*
oldturkey03 tarafından
If you need any guidance as for the location of the components, post some highres images of your logic board with your question. Use this guide Adding images to an existing answer to assist you with that.
Hi to both of you,
First of all I wish to everybody a Happy 2014!
Sorry for replying a bit late but I finally found someone to replace the shunt and the wled driver which I have bought separately. He also checked the display.
The original display was LP133WP1 TJA7
The one that I got for replacement is LP133WP1 TJA3 and I hope that there is nothing wrong since both of them are LP133WP1?
However there is no output on the display yet. On the picture that I'm attaching here, I can see that there are 2 parts that have no voltage.
One is a circuit and the other looks like an SMD capacitor or a resistor? (since it's not closed circuit when tested with a voltmeter)
Do you by any chance have the schematics of the motherboard or can shed some light on what this parts are ?
Vlado tarafından
Hi again, I just saw that you already listed the part which I was wondering about and that's the FPF1007/8/9 on which there is no voltage. Do you know by any chance what is the small part on my last image ? It looks like a small capacitor or a resistor ?[image|310885]
The wled driver and the shunt monitor were replaced successfully and the original display was LP133WP1 TJA7 The one that I got for replacement is LP133WP1 TJA3
I messed up my comments again sorry :(
Thanks in advance,
Vlado
Vlado tarafından
Hello,
I have the same problem after display assemply replacement I have no backlight, the fuse is ok
I have a macbook air A1465 early 2015
Can you help me please ?
Thank's
Beraich tarafından
