Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
MacBook backlight dies at certain screen positions, almost unusable
Hi, all! I have a 2.2 C2D MacBook that's less that three years old but becoming almost unusable as the screen backlight goes dark unless it is partially closed. This is something that has gotten progressively worse over time, from one "bad angle" to a wider and wider arc and now it is really bad. I have been told it's a cable issue or an inverter issue or a display issue...how to narrow it down?
Bu iyi bir soru mu?
Puan 0
5 Yorum
Thanks very much! I am about to order the cable and have a go at it. If I am going to take things apart to do this, are there any other fixes or low-cost upgrades I should do while I'm in there? Cheers, Matthew
tarafından
Maxing the RAM is relatively cheap.
tarafından
- Dust off internal components and logic board with compressed air (can).
- Visually check all cables and connectors
- Check if all screws are tighten enough on logic board and internal parts
- Remove the optical drive, unscrew the 3 top philips screws, dust off the internal mechanism, the case slot and clean the laser lens with a Qtip and isopropyl alcohol. Apply teflon based grease to moving arms:
http://www.sherline.com/7550pg.htm
- Fan: dust off the fan, lift the top round sticker and inject a drop of sewing machine oil in the top center hole, put back the round sticker and add a piece of scotch tape on it.
http://www.amazon.com/4-oz-Sewing-Machin...
Top case: turn it upside down and gently tap on it to dislodge small particules stuck under the keys. Finish the job with compressed air between the keys.
tarafından
Matthew - did the cable work?
tarafından
No, it didn't. I went through the whole process to take everything apart and replace the cable, but the problem has not been fixed. At this point I am planning to wipe the hard drive and take it to a local technician to fix as a last-ditch effort, otherwise I'm in the market for a new Macbook, or maybe an iPad.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try using the computer with an external monitor. If it functions properly the you are looking at a LCD, inverter or cable problem. My best guess based on your description is a faulty cable and I would try that first. However if it does not work with the external monitor then you probably have a logic board problem. Ralph
MacBook Core Duo Display Replacement
Bu yanıt yardımcı oldu mu?
Puan 3
6 Yorum:
Agreed on the cable being the problem. +
tarafından
It does work fine with an external keyboard and monitor...and the image is still visible but unusable when the backlight is dead. Now...where to get a new cable?
tarafından
I think this is your part but check with the folks at ifixit to be sure. Ralph
http://www.ifixit.com/MacBook-Parts/MacB...
tarafından
Yes bad inverter cable. When replacing the cable the OP should also take a look at the microphone cable that often has damaged skin near the hinge. A small piece of electric tape will correct the issue.
tarafından
nice hint lemerise
tarafından
1 tane daha yorum göster
Yorum Ekle
I recently fixed a friend's macbook that had this issue - the backlight shutting off as you open the screen. In bright light/sunlight you can see the display is still on and everything else is working fine. When you close the lid, the backlight would come on just an inch before it was closed.
The backlight power cable runs on the left side, it's quite short, and I assume due to poor assembly (refurb?), the cable is easily routed under the left hinge (which holds the cable down) in a way that it pulls it loose in some positions. You may see the connection to the logic board on your left, it's rectangular and tiny.
I removed the display bezel, left hinge and round cover over the center on the bottom of the display. I probably took apart more than I needed to. Reposition the cable so it has a little more slack behind the hinge. You could move it around until it doesn't pull tight and then tighten the hinge down, (and the display backlight stays on in any position).
As far as I know, the problem has not reoccurred. Good luck.
Puan 2
1 Yorum:
Can you give a part number for a "backlight power cable"
tarafından
Yorum Ekle
I too had this problem (twice) with client computers. In both cases (for me), replacing the backlight cable that connects from the logic board to the inverter, fixed the issue. It's also worth noting that you don't have to completely remove the optical drive, display, etc as the iFixIt guides show. You can simply pop the top cover off and remove the LCD bezel and go from there, saving lots of time.
Puan 1
1 Yorum:
Here's the guide I wrote on doing just that: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
tarafından
Yorum Ekle
The major problem with the mac book proof is the monitor cord which lead to the screen. I have develop this same issue of the backscreen going off. The first thing to do is to pull the computer screen, once u get into it u must ensure that all the screws that lead to the monitor is tighten, the solver for this problem is to gentle pull the power cord that lead to the monitor in order to release the tension on it. The power cord is next to the left hinge so when you flip open your laptop too much pressure is on it so the monitor light will go off
I have done this to mine and two more friends as well and neither of us never ever see the problem occurring again.
Also please please be careful how u open the screen it can be of real hassle.
Puan 0
Yorum Ekle
This used to commonly be the little cable going from the inverter to the board. In 2014, this machine being six years out of production, it can be absolutely anything. The screen light, the board, the inverter board, the cable.
Also expect every one of those cables you find on eBay to be pulled out of laptops used for the past eight years and for them to be almost as dead, if not as dead already, as the cable you are taking out of your computer.
This is an absolute nightmare to fix in 2014 because all of the parts you will be buying are junk. :(
Puan 0
Yorum Ekle
I had this same issue, where the display backlight would not work at certain screen angles, and it got worse over time until the backlight just wouldn't come on at all. I was able to take off the back, and push some of the display cable back into the screen channel by the hinge and it would turn back on. I also bought a replacement part from ifixit, but once i saw i could improve it again without going through the entire process to heat gun and remove the glass from the screen to get to the connectors i decided to leave it as is for now since it is workable again.
Puan 0
Yorum Ekle
Yanıtını ekle
Matthew Long sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 23,886
