Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20010 Soru Tümünü görüntüle
Soru Kapandı
Why does mds process heat up CPU after hard disk install?
I recently installed a new hard disk on a MacBook Pro Core Duo 2.0 GHz and migrated accounts from the older disk. The Activity Monitor has started showing the mds process ramping up suddenly and dominating the CPU usage at over 100% -- occasionally as high as 170%. Then the process dies down until something else causes it to ramp up again.
After two days without problems, this cycle has begun to repeat itself. Can someone explain why this would happen, and why so sporadically? Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
What hard drive did you install? What speed?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hitachi 320GB 5400rpm. About 100GB is being used. The MacBook is running MacOS 10.6.3. FWIW, I stepped away from the machine for a couple of hours and came back to find the mds process running intensely.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 759
