Ana içeriğe geç
Haziran 2009'da piyasaya sürüldü / 2.66, 2.8 veya 3.06 GHz Core 2 Duo İşlemci
Location of the WLED driver
Resim
Can someone tell me where the WLED driver on this Macbook Pro? This is a Macbook Pro 15" 2.8Ghz Mid 2009 EMC 2324. I have also included pictures. Thanks in advance.
Resim
Resim
Resim
I'm sorry, but I couldn't find the last three digits of my serial number.
Bu iyi bir soru mu?
Puan 2
7 Yorum
Kevin, not sure where you posted your images:-) use this guide Mevcut bir cevaba görsel ekleme to post your images with your question. Also, it will help tremendously if you give us the last three digits of your computers serial number.
tarafından
I just uploaded the pictures. Sorry about that.
tarafından
Hey, no problem:-). do these look like the specs for your computer:" 2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MC118LL/A Model No: A1286 (EMC 2324*)
Subfamily: Mid-2009 15" Model ID: MacBookPro5,4
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
tarafından
No, but I think this is it (mine has a 2.8 Ghz) :
Intro Date: October 14, 2008 Disc Date: March 3, 2009
Order No: BTO/CTO Model No: A1286 (EMC 2255)
Subfamily: Late 2008 Model ID: MacBookPro5,1
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
tarafından
Kevin, check the EMC number on image #1 it shows EMC 2324. you sure about the EMC 2255?
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Kevin, for the EMC 2324 as it shows on the images you uploaded, the LCD backlight driver has reference designator U9701. It is a LP8543SQX manufactured by TI. the datsheet is available right here. The part itself seems to be a bit hard to come by, but it is available :-) Hope this helps, good luck.
Resim
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
Thank you very much for your help.
tarafından
where can I get the replacement piece? thanks
tarafından
Yorum Ekle
Yanıtını ekle
Kevin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 25,277
