Ana içeriğe geç
Sabit sürücüler veya sabit diskler hakkındaki onarım bilgileri. Sabit sürücüler, manyetik veri depolama aygıtlarıdır. Düşük maliyetleri ve yüksek veri yoğunlukları nedeniyle çoğu masaüstü bilgisayar, dizüstü bilgisayar ve sunucuda kullanılırlar.
Compatibility in swapping out the PCB...
Hi all -
So I'm wondering if anyone has any knowledge about swapping out the PCB (printed circuit board) on 1.8" HDD....
I have this Samsung model (Samsung HS16VJX - 1.8" HDD 160GB) where the OEM PCB is a direct to USB port. I need a ZIF drive (yes, for an iPod) and found someone with a PCB for a Samsung HS081HA 80GB 1.8" ZIF Hard Drive. Thought about purchasing it and hoping for the best, but would prefer to have some confidence behind spending the money.
Let me know. Much appreciated!
Jason
Bu iyi bir soru mu?
Puan 2
1 Yorum
Yeah... that much I knew. I just thought perhaps since they were both 1.8 Samsungs, I had a much better chance of it working. Just wondering if anyone else has had success. Thanks Cris
Jason
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
you can try it.
But every drive has a memory chip on the PCB that stores unique informations about this certain hard drive. If you buy a PCB from another drive the stored informations may not fit to your drive.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
agreed +
tarafından Paylaş
Yorum Ekle
I have successfully received the PCB,I replaced the BIOS chip on the PCB by the original and it has worked perfectly.I was able to retrieve complete information from the hard disk. Wish this can help.
Puan 1
Yorum Ekle
I own exactly the same drive (HS16VJX ) and I’m looking for a PCB to salvage data.
@jcarter: it appears you chose @crib’s solution, but it’snot clear wheather it worked for you or not? Did you do as James Yu wrote and replaced the BIOS chip?
Thanks in advance,
Calagan
Puan 0
Yorum Ekle
Yanıtını ekle
jcarter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 2,604
