Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
lock button failure
I need to troubleshoot why my screen isn't working after A took the working headphone jack from a iphone 3GS and installed into an Iphone 3G. It all went together smooth but when I got to testing, I tested with the screen not latched all the way so if it didn't turn on it would be easier to remove. well it turned on but when i started to click the screen in place one of the #1 or #2 stickered ribbon cable connections came unlatched and the screen went black. I thought, no problem I would re hook up and turn on and the screen would work but it hasn't.
I have let the battery run out (it was dead to start so didnt take long) and removed and reinstalled the screen, plugged into charger and it still makes the ding like it is booting up but it doesnt show apple logo or anything.
Any ideas on something I can do, check, or replace?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
1 Yorum:
I just plugged it in again and this time it gave me a white screen, I kept it on the charger longer and it loaded up after the white screen like it should, the only problem is the problem that I was trying to fix the first time, the lock button doesnt work, I already salvaged the headphone jack from another broken iphone of the same version, any ideas where to look next?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You can get replacement parts from apple but they will be $100-$200 never got replacement parts thow sorry.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Yanıtını ekle
Eric H sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 74
