I forgot my Galaxy Mini password, how do I reset it
As I switch my phone on, It requires a (pattern) password and I have forgotten it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
If you make some wrong entries the phone will offer you to log on with your google account. But you must have WiFi connection. You can't make new connection and your WiFi must be turned on from before.
The second way is with adb commands. But for this you must have enabled USB Debugging from before. Otherwise you can't connect it with the PC.
The third way is Factory Reset but you will LOST all your data. Push and hold together vol(+) and power on keys.
With vol(-) chose Factory Reset. The power on key is for ok.
Samsung Galaxy S5 - Password, Screen Lock Removal
Regards.
Bu yanıt yardımcı oldu mu?
omg it worked thank you and keep up the good work
1-code formati https://www.facebook.com/rebels.tn.3
2-conneceter sur wifi entre email et mot passe
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 15,375
3 Yorum
Did you set a pin number incase you forgot your pattern?
Cammy tarafından
No I never set a pin number
ant7210558 tarafından
wifi and bluetooth not working
wwwharisfarooq tarafından
