Ana içeriğe geç
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
No Backlight After Screen Repair
I managed to crack my screen. I replaced it with a new screen provided by the famous iFixit.com
When I put it back together, I lost the backlight. I can see the very dim screen. The digitizer works fine.
Anyone have the location and/or fix for the backlight fuse on the new Mini Retina? I see that there is a fix for the 1st gen Mini. Can't find one for the new retina model anywhere on the interwebs.
Thanks.
Update
Well. I knocked out the wrong IC. Before, I would turn on the ipad and the Apple logo would flash nice and bright, then it would dim and continue the boot up.
Now, I turn it on and the Apple logo is immediately dim but I continues with the boot up
Oh well. Maybe in the future ill be able to get a new circuit board. The ipad was only 2 weeks old.
Bu iyi bir soru mu?
Puan 0
2 Yorum
post a picture of what you did.
tarafından
Anyone with a diagram or that can post a picture would be greatly appreciated.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nope--haven't seen a mini 2 yet, but if you find the diode leg, you can probably find the fuse by testing for continuity from the leg to the fuse, then from other side of fuse to the LCD.
I've been doing a lot of iPad mini backlight repairs lately, feel free to ask any other questions.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
Found the backlight fuse for the mini 2 retina display!
tarafından
Ok so, I have a Backlight Repair kit. Comes with IC, Filter and Coil. However, where the Filter would be, is blown to a point where the copper that the Filter would be soldered onto, is missing. Wouldn't be such an issue and could be delt with soldering a wire to where ever the Copper feed runs to on the circuit board. However, we don't know where it runs to and we need a schematic of the circuitry to find out.
Does anyone have a link or any information that could help us with this?
tarafından
I gave advice on this under your comment in the question Screen stays black after digitizer replacement
tarafından
hi jessabethany you said you found it but have post a photo somewhere?
tarafından
Honestly iPad mini retina rarely has blow backlight fuse--it is not sensitive like the original mini. If it is blown it will look burned under the microscope. If not you probably have led damage and/or need a hard reset
tarafından
Yorum Ekle
En Yararlı Yanıt
http://imgur.com/4XAaEHG
Here is the image ya'll were asking about. The backlight filter is in red. The backlight diode is in green.
Puan 2
4 Yorum:
http://i.imgur.com/ANjIGwe.png
Here is another image with trace marks
tarafından
Are u available to fic back lights for our ipads and i phone?
tarafından
Hello yaya, could I have your contact info, thanks, I suspect a backlight going out on my wife's ipad2 and maybe some pics showing sure the backlight ic chip is and the component labeled 4r7 is. Thanks.
tarafından
what do i need to do ????
remove this components??
tarafından
Yorum Ekle
So if the above mension are not blown and its got output 4. Something dc voltage, is it means the LCD inverter modulator are damage? And need to replce the lcd?
Puan 0
Yorum Ekle
Yanıtını ekle
Jose Serrano sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 13,117
