Ana içeriğe geç
The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
25 Soru Tümünü görüntüle
How do we Replace either the Micro-USB OR micro-HDMI jack?
Before commenting, please know: I KNOW where to order the jack parts, I just need to know HOW to replace them.
2nd and sometimes even 1st of the major two problems of the D4 was not just the battery, but relatted, the micro-usb port failure.
Although there is an excellant micro-usb cleaning video on YouTube (and that does work in most cases), what is clearly lacking but needed should be within the teardown, we need to see how to replace the micro-usb and micro-hdmi jack ports. We don't even see pictures of their freedom! Frankly only mentioned as to their existence. Please add to and change the teardown to explain this procedure (should be part of the teardown, shouldnt need to be a separate video)
Also , where can we get the exact same OEM jacks -I see alot of Razor links, but nothing for D4 yet.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
pretty much impossible, they are micro soldiered to the main board. I have tried doing the same thing on a htc evo 4g and even the nano fabrication lab at my technical school could not perform the repair.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
So, then, I would need to just order that board (35.00 OEM on Amazon)?
tarafından
if you are talking about the main board yes!
tarafından
Yorum Ekle
Yanıtını ekle
Dan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 346
