Ana içeriğe geç
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Soru Tümünü görüntüle
How can I keep my display glass from falling off?
I have a MacBook Pro Mid-2009 Unibody (A1286, MacBookPro5,3). I've successfully done a number of repairs (several DVD drives, hard drive upgrades, memory, etc), but this last one has me stumped.
About a year ago, the display glass started to come off. It's held on by a ring of what is basically high-quality double-face tape. My guess as to the cause is that I use it about 8 hours/day in Firewire Target Drive Mode, and it gets pretty hot. Either way, the tape fails, and the glass comes right off, leaving the LCD and aluminum frame exposed.
Since then, I can't get it to stay on. I've replaced the tape twice (two different vendors) and the entire glass once (from Ebay, with presumably Apple-supplied tape). I've cleaned surfaces with alcohol. I've heated the tape, put the display under pressure (the Complete Far Side is just the right size) and left it overnight. I now keep a sheet of foam sandwiched between the display and the body in Firewire Target Drive Mode to keep the heat down. But, no matter what I do, in a couple of weeks or months it comes right back off.
I'm almost to the point of running a bead of silicone around it to hold the darn thing on, the heck with the appearance, but opted to post here in case anyone had any suggestions.
... Any ideas?
Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
After replacing the tape supplied by Apple, use a heat gun to go around the perimeter to help melt the adhesive. Use a soft cloth to press it down after it's softened.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I did this the last time I tried, and the glue didn't seem to last any longer. I'll try it again, only more enthusiastically.
tarafından
Yorum Ekle
I replaced my screen and the replacement wouldn't stay on after my computer heated up. I tried a few types of double stick but eventually solved it using clear butyl. It's meant for installing car windshields, but I bought it at a camera supply store. Search for film expendables store to find something in your area. The type I used was a bit too thick but I just stretched it as I applied to thin it out. Hope that helps!
Puan 1
Yorum Ekle
Yanıtını ekle
griscom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 2,105
