Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Replaced iPhone 5 battery now phone won't turn on
Hi, I replaced my iPhone 5 battery and now it won't turn on. I tried rebooting it, nothing happened. I tried hitting the vibrate button to see if it was the LCD and no vibrate. I have had it plugged in now for 30 min to see if the battery was just dead and it still won't turn on. Any suggestions?
Bu iyi bir soru mu?
Puan 28
7 Yorum
ok so i let it sit charging and now its on but its stuck in recovery mode. it restores and then just says its in recovery and that I need to restore it and it continues in that cycle...
tarafından
Did you try to place it in DFU mode, then restore?
tarafından
Giovanni. Did you pry the battery out between the battery and the logic board or between the battery and the housing?
tarafından
battery & board as shown in youtube
tarafından
hey my iPhone 5 was working fine until it fell and front screen cracked, took it in for repairs was told the battery was swollen so i had it changed along with screen
now the phone wont come on. was also told my charging port was not working this does not make any sense
please help anyone.thanks
tarafından
2 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
Fun fact: Some aftermarket / bad quality batteries do not allow you to restore your phone and cause the issues you are having.
Buy a quality battery such as ones from iFixit or eTradesupply.
Also check the charger port for any dust or lint. If there is, use a toothpick or equivilant to clean it out.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I had the same problem. Took the phone apart again and I had the black piece from the battery on the leads wrong. I had to make sure I carefully put the little piece between battery & mother board, then put the leads on the board. Phone works again! Awesome! I praise God for helping me understand what I had done wrong. I hope I explained it well. Hm, the little piece that is attached to the battery with the leads on it-at first I was just placing it on the motherboard, what happened is the little piece of plastic was covering the leads, so motherboard could not read it. I took the little flap & unfolded it off the leads then put that down between the battery & motherboard & then the area with the leads laid on the motherboard and viola, the phone works with new battery! Yea!
Puan 3
Yorum Ekle
Tried everything else and nothing work for me. What did work after 15 tear downs was changing the orientation of the cable. Basically a replacement battery requires you to fold the ribbon yourself so it is in the correct position for the connector to attach and the ribbon to fit down between the battery. First I folded the ribbon the same way as the battery I removed from the iPhone. The iPhone would turn on no problem if I had the screen not fully fitted back into position, as soon as I would push it down it would go off and wouldn't start. Pull it up again with suction cup and it worked again, seems to have been a grounding/shorting issue.
As a last ditch effort I carefully bent the battery ribbon with the connector in the other direction opposite of the oem battery (over not under) and it worked perfectly ever since. Hope this makes sense and works for someone
Puan 2
1 Yorum:
by far the mist helpful thank you I wouldn't have thoughof that before giving up and buying new parts lol
tarafından
Yorum Ekle
1. Double check the battery connector and front panel assembly cables are reseated properly.
Puan 1
Yorum Ekle
If the power and home button don't work then you have damaged componants that surround the battery connector and most sumthing else that's y the phone will not turn on
Puan 1
2 Yorum:
hey,I can hear the sound of when i plug my charger in and it will allow people to ring me, I just cant see the screen, so have I damaged it or is something not correctly been placed ?...courtney
tarafından
maybe you didn't reconnect the screen properly. did you solve the problem ?
tarafından
Yorum Ekle
My problem was the display. I replaced the display two weeks before with an aftermarket LCD. It is possible that was damaged when I reopened it. I put back my cracked original LCD and it started back again.
Puan 1
Yorum Ekle
I had this issue with a sprint Iphone 5. Disconnect the battery and plug the phone into the computer. IT will power on. Use tiny umbrella to force it into recovery and install ios.. You will get error 2001..
Once that happens.. Unplug the phone and connect the battery. Force the phone into recovery with tiny umbrella and install ios again.
If you are still in recovery use tiny umbrella to force the phone out of recovery.
Puan 0
3 Yorum:
Also a Sprint iphone 5. But I think the power button is also not working cause I could not turn it on without the battery and with the battery the only way to turn it on is if I just let it charge. So I'm assuming the power button is not working. And because I cant get it to turn on without the battery, it is not recognized in tiny umbrella. If I use tiny umbrella with the battery it just restarts and goes right back to recovery mode just like restoring it in itunes does...
tarafından
Tiny umbrella?
tarafından
What is the difference between the iPhone 5s and the sprint iPhone 5s?
tarafından
Yorum Ekle
I had a very similar problem with my old iPhone 5. Long story short: I had a Black 16GB iPhone 4S, the screen got cracked and the Wifi Chip broke (Under settings the Wifi option was greyed out). I payed $60 for an issuance replacement by AT&T (Asurion). Each "refurbished" iPhone 4S they sent me had problems (they sent me 5 iPhone 4S's each one had a problem), so they felt bad and sent me a Space Grey iPhone 5 64GB. Unfortunately for me I quickly discovered there was a battery problem, and I ignored it due to the fact that I was given a great upgrade. It came to the point where it was charged at 100% and would it last about 2 hours maybe less. So, I replaced the battery with one from iFixiT, and after replacing it the phone wouldn't charge or power on, even after putting the old battery back in. Anyways, I called AT&T one last time and they said they were so sorry for the trouble, and to show their graditude they sent me a brand new Space Grey iPhone 5S 32GB (to ensure I wouldn't have any more problems cause its new). Ok it's a rather "long" story Lol.
Puan 0
2 Yorum:
How lucky can one be!
tarafından
Right, I have never been successful with a diy on ekectronics. They are very sensitive and hard to fix. Best for me is to get a ebay refurbished as it’s guaranteed for a year
tarafından
Yorum Ekle
Yanıtını ekle
giovannigomez13 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 40
Her zaman: 82,020
