Ana içeriğe geç
Kindle 4'ün 28 Eylül 2011'de piyasaya sürülen 4 modeli bulunmaktadır.
Kindle will not switch on
my kindle was fine when I switched it off, but will not turn on again. I have tried this with the mains connection on & off. When pressing the on/off button, the green light comes on, briefly, then --- nothing!
The charging light seems to work, but the kindle will simply not boot! Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
6 Yorum
the back won't come off
tarafından
got the back off wares battery
tarafından
kindle 4 will not let you take it out what do i do how
tarafından
the battery is glued down
tarafından
I fixed it by disconnecting and reconnecting the battery. I followed this tutorial: Kindle 4 ekran değişimi until step 2, then reattached the battery and reassembled the back.
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the same problem as you.All you need to do is hold in the start button for 20 seconds and it will reboot the kindle and it will reload everything.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Worked for me! I think my initial problem was I left the kindle battery to drain for too long. I need to remember to charge it. Thank you!
tarafından
Yorum Ekle
i had the same Problem with a kindl. Disconnect the battery from the logic board, wait for about 2 minutes and connect the battery to the logic board. This helped me...
Puan 0
2 Yorum:
After watching fixit so knew how to take back off ,I followed advice about disconnecting battery did this left for few minute.....now have a working kindle again.
tarafından
can you direct me to get the instructions for removing the back please as i have the same problem.
thank you
tarafından
Yorum Ekle
I am having the same issue. How do I open Kindle 4 to do this? Can someone please direct me to a good, reliable set of instructions? Thank you.
Puan 0
1 Yorum:
yes i would like the instruction
tarafından
Yorum Ekle
Yanıtını ekle
Denis Keenan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 3,252
