Ana içeriğe geç
Jeep Grand Cherokee, 1999 model yılı için yeniden tasarlandı; 2000 modelleri ise çok az değişiklik içeriyor. Bu model, Jeep WJ olarak da bilinir.
Steering wheel column lock
How do you repair a bad or bent steering column lock?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Cliff Corriveau, looks like you will have to replace the ignition lock. Here is what the service manual says:
"WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, REFER TO 8M - PASSIVE RESTRAINT SYSTEMS BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.IGNITION SWITCH REMOVAL
The ignition key must be in the key cylinder for
cylinder removal. The key cylinder must be removed
first before removing ignition switch.
(1) Remove key cylinder. Refer to previous steps.
(2) Remove lower steering column cover screws and remove cover (Fig. 19).
Resim
(3) Remove ignition switch mounting screw (Fig.17). Use tamper proof torx bit to remove the screw.
Resim
(4) Using a small screwdriver, push on locking tab (Fig. 15) and remove switch from steering column.
Resim
(5) Disconnect two electrical connectors at rear of ignition switch (Fig. 17).
IGNITION SWITCH INSTALLATION
The ignition key must be in the key cylinder for cylinder removal. The key cylinder must be removed first before removing ignition switch.
(1) Before installing ignition switch, rotate the slot in the switch to the ON position (Fig. 16).
Resim
(2) Connect two electrical connectors to rear of ignition switch. Make sure that locking tabs are fully seated into wiring connectors.
(3) Position switch to column and install tamper proof screw. Tighten screw to 3 N·m (26 in. lbs.).
(4) Install steering column lower cover."
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I wish you had posted the size of the tamper proof screw :(
Puan 0
Yorum Ekle
Yanıtını ekle
Cliff Corriveau sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 8,973
