Ana içeriğe geç
1903 yılında kurulmuş olan İngiliz otomotiv üreticisi tarafından üretilen araçlar için onarım rehberleri ve destek.
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
6 Yorum
What year is your Vauxhall?
tarafından
It's a 2005 55 plate
tarafından
Does that relay also control the reversing light?
tarafından
any more my light do not work 1.9 vauxhall combo reg 04
tarafından
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
Resim
Resim
information from here
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
That's a great help.
Many thanks.
Geoff
tarafından
You are welcome, best of luck to you.
tarafından
This was really helpful to me many thanks
tarafından
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
tarafından
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
tarafından
Yorum Ekle
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
Puan 0
Yorum Ekle
Yanıtını ekle
Geoff Heyes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 46
Son 30 gün: 174
Her zaman: 34,642
