Ana içeriğe geç
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
42 Soru Tümünü görüntüle
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Puan 2
Yorum Ekle
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
Puan 1
Yorum Ekle
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
Puan 0
Yorum Ekle
Geniiioooouuussssss!!!!! Thanks a lot!
Puan 0
1 Yorum:
Which answer helped you?
tarafından
Yorum Ekle
SIM card in my phone but
No SIM card shows me
Please halp mee
Puan 0
Yorum Ekle
Yanıtını ekle
Ravi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 24,126
