Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Soru Kapandı
power button and several keys not working
I have a white macbook White late- 2009 A1342 macbook Duo
The power button and several keys on the rights side of keyboard do not work . Can only power up by jumpstarting.
Any way to further diagnose tried pram and smc reset.
Might I need to replace ribbon cable or keyboard/topcase
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes - top case replacement. Sounds like spill damage. Check in side for corrosion.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
No spill damage but maybe keyboard cable was damaged? Do I still need new top case - any way to put in new ribbon cable only. New topcase $150, used macbook ebay $320 best choice?
tarafından
You can start with the cheaper fix… I have no way of knowing where the damage is. If you need/want other parts on hand maybe the used MB is a good investment.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 676
