Ana içeriğe geç
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
How 2 fix an iPad thats screen just went black?
it worked FINE the my Daughter logged into an app for Valentines Day, now the screen is all black and it wont turn off or back on. When you plug in the charger...nothing, hit any buttons...nothing?? What do i do? PLEASE help, single Mom not alot of money, so can't afford to take it in to be fixed.
Bu iyi bir soru mu?
Puan 61
61 Yorum
My iPad mini was charging and my daughter went to go on It and it would not go on..it I a only a year old and I called the help center and they told me that I was out of warrenty and that's why it happened so how can I turn it on
tarafından
after that you have to unlocked the screen by switching on the right upper button that sits beside the screen, then you have to turn off the voice over by double touch on screen for setting option under "General" then "Accessibility"
tarafından
So thankful I came across this post! Whew, thought I had to buy a new iPad :-).
tarafından
Wow. This just happened to me too! Mine is also just a little over a year old. Holding the home and switch button for 20 seconds worked. THANK YOU!!!
tarafından
Thank you!!!! I happened to google "my iPad went dark?" & it brought me here. I have created an account and will come back for answers!!
tarafından
56 tane daha yorum göster
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
Do a hard restart ..
Hold power button and home button togeather at same time for about 7 seconds then let go off home button and keep pressing power.. It should restart!
Bu yanıt yardımcı oldu mu?
Puan 102
111 Yorum:
thank you!!!!!!!!!! Just the answer I was looking for:)
tarafından
Thanks for this, it has just helped us as well!
tarafından
thank you. om g. it worked! life saver. thank uuuu
tarafından
My screen did the same thing but it is not coming on
tarafından
it worked…thank you
tarafından
106 tane daha yorum göster
Yorum Ekle
After that you have to unlocked the screen by switching on the right upper button that sits beside the screen, then you have to turn off the voice over by double touch on screen for setting option under "General" then "Accessibility"
Puan 2
1 Yorum:
We just returned from a trip to Europe and they made my son check his bag at the gate last minute. We were sure it was somehow damaged during transport, but THANKS TO YOU, I was able to fix it. I'm so appreciative of people like yourself who are willing to share the knowledge so many of us don't have a clue on. BLESS YOU !!!
tarafından
Yorum Ekle
Plug it in to recharge it.
It worked for me.
Puan 1
2 Yorum:
Thank you, thank you, thank you, just got for xmas and was ready to burst out in tears! Thanks again!
tarafından
Definitely, this was helpful.
My gadget restarted and black screen disappeared!- Kedrick.
tarafından
Yorum Ekle
try pressing home button and Switch button Simultaniously for 20 seconds. Apple logo will come and thats it.
Puan 1
Yorum Ekle
Go to settings then general check lock and unlock switch off if on make sure it is not green.
Puan 0
1 Yorum:
Many thanks - worked perfectly.
tarafından
Yorum Ekle
I was minimizing my screen with my fingers and my screen went black. I could see the icons through the screen but it would not go away. I tried to use your idea of pushing the home screen and the on and off button together for seven seconds and rebooted it but it still came back the same way any other suggestions.
Puan 0
1 Yorum:
Try waiting until battery flat before recharging. Also try switching off for a few minutes.
tarafından
Yorum Ekle
My ipad 2 screen blacks out for about 30 seconds then comes back on. It does this often
Puan 0
1 Yorum:
Rebooted it. It works fine now.
tarafından
Yorum Ekle
I need help.. I don’t know what happened but my ipad mini 2 screen is black when i turn off and turn it back on. I have to restart again and again when this happens. I need a solution,
Puan 0
1 Yorum:
So once you turn it off and on again it’s ok? It happened To me once and I could see in the background underneath all that black where I was able to get to my settings and lighten my screen. I guess what I was seeing was my screen turned down to the lowest amount of light. Then it was fixed.
tarafından
Yorum Ekle
i have same trouble if you turn locks off i dont get black screen any more but after a hour of useing it iturn my ipad off for a hour then back on so it cools down
Puan 0
Yorum Ekle
Charge for 1 hour then turn side switch from off (Red) to on again! Work perfect at no cost.
Puan 0
Yorum Ekle
My Ipad 6th gen decided to went black screen after just pressing the power button, I tried to hard reset it, restore it and put it in dfu mode or recovery mode but it still wont work. This happened to me 9-10 months ago and it went back ok for just a few weeks by leaving it to drain its battery for months and it happened to me again and its been 5 months now, but when I put a flashlight above the screen it will show some display.
Puan 0
Yorum Ekle
My ipad mini 2 screen turns black when I unlock it. I tried so many restarts but its still the same. whenever I lock my ipad, when I want to unlock it, its screen turns black. can someone help me with this?
Puan 0
Yorum Ekle
Yanıtını ekle
Melissa Louke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 231,736
