Where is the turnsignal flasher on 94 cavalier?
I found the hazard light flasher but not the turn signal flasher
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Johnny Hale, the turn signal flasher is located located behind the instrument panel, on the left side of the steering column bracket. Replace the flasher by unplugging the old one and plugging in the new one. (usually;-) Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Thank you! Your diagram is way better than the one in the Cavalier shop manual.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 3,081
