when I turn on my camera it says lens obstruction
Ok so when I try turning my camera on it says lens obstruction and the lens wont come out and after awhile it turns off.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Juanita Gonzalez, this is most likely caused by a stuck lens. These errors are more common with an extended lens, but can also appear in a retracted lens. Take a look on here to see how to deal with it. It will be the same for most brands. If this does not work, you may be looking at replacing the lens itself. Since you did not tell us what model your camera is, we can not provide any further details with that. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
my camera is a kodak easyshare c195 14 megapixel with 5x optical zoom.. any tips??
Mine is a Kodak Pixpro AZ251, and I know I deopped my camera, and after I dropped it It said lens obstruction, restart camera. what do I do now?
Im having the same problem with my GE X500 Camera..pls need a solution .thank u
i have the same camera with the same problem
my camera doesn't work and it always says that lens obstruction. what should i do?
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 56
Her zaman: 21,410
9 Yorum
I had experince too
noel tarafından
My camera brand GE 14.1 megapixel E1450W
noel tarafından
i tried to turn on my kodak pixpro az252 and it says lens obstruction and turns off how do i fix it
Marci Faro tarafından
Mine is a BRAND NEW Kodak PIXPRO AZ252 Bridge Camera. I had just opened it the day I bought it and it said lens obstructed Restart camera and then it shut off. I am really mad. The shutter and lens does not even come out.
Juliann (Esther) Headrick tarafından
Same how do you fix it I have the FZ41
Imissbabycoco Resendiz tarafından
4 tane daha yorum göster
