Ana içeriğe geç
HTC One (kod adı M7), HTC'nin 2013 yılı amiral gemisi telefonudur. Kusursuz tasarlanmış yekpare alüminyum gövdeye, ön tarafta 2 adet büyük hoparlöre ve 4.7 inç 1080p ekrana sahiptir.
149 Soru Tümünü görüntüle
HTC One: After reassembly no GPS-Signal
I replaced the complete Front (Display, Touch, Frame).
After reassembly I have no GPS-Signal at all.
I Really don't think so but maybe I forgot to connect a cable or something.
Does anybody know where the GPS ist located on the motherboard?
Is there a GPS-antenna and where?
Thank you so much
Thmas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
May be you have problem with antenna connector. Disassemble it again.
Look here:
HTC One Teardown
In step 16 you can see some golden contacts.
Push them up (carefully, you can broke them).
And check back housing on the places where they make contact. I'm not shure which one is for the GPS. You must have connectors for GSM, WiFi, GPS.
Regards.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank You for answering my question.
I dissambled it again, including mother- and daughter-Board. I checked all contacts I saw. They looked fine but again I pushed them up. Just for sure.
But still no success, GPS isn't working :-(
Is there a possibility to check the GPS-Hardware?
Thank You very much
Regards
Thomas
tarafından
wifi no signal
tarafından
Yorum Ekle
I replaced the cameras and charger port and then the GPS stopped working. I took an emergency trip to help my brother and got lost. Contacted HTC and they said it would be about a two week and $150.00 fix. Found this and fixed GPD in three minutes.
http://forum.xda-developers.com/htc-one-...
Puan 1
1 Yorum:
Great. Noticed same.
tarafından
Yorum Ekle
you may missed to plug back the small antena beside vibrator , i just discovered my mistake, it was left under motherboard xD
Puan 0
Yorum Ekle
Yanıtını ekle
Thomas Dott sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 7,269
