Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Soru Tümünü görüntüle
Internal keyboard and trackpad intermittently not working
Sometimes on boot up trackpad and keyboard will not work although a remote mouse plugged into USB port works ok but the keyboard still does not work.
If unit dropped about 3 inches on carpet (naughty i know ) works again, although sometimes stops working again whilst in use.
I suspect a loose cable/plug. Any ideas?
Bu iyi bir soru mu?
Puan 1
1 Yorum
trackpad socket on logic board broken away from soldered joints
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yep, if you drop it and it works then a cable will be loose. Basically, make sure all the connections to the logic board featured in this guide are in properly.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
found trackpad socket had broken away from logic board on soldered joints
tarafından
Yorum Ekle
Yanıtını ekle
Petethefish sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 3,261
