Ana içeriğe geç
Beşinci Google Nexus telefonu. 31 Ekim 2013'te resmen duyuruldu; 4,95 inç 1080p ekrana, 2,26 GHz Snapdragon işlemciye ve LTE desteğine sahiptir. Android 4.4.2 KITKAT ile çalışır. LG tarafından üretilmiştir.
Nexus 5 Touch Screen stopped working
okay so I dropped my phone in water, I know, lame but here is what is going on:
After I did that, I opened the phone up, placed it on rice for a few days.
It turns on fine, it rings, I get notifications and for about 5 minutes, I was able to use it but then the touchscreen stopped working.
It does not recognize touch at all. It did off and on for a few more times after that.
I placed it in rice again for another day with no improvement.
I am wondering if someone can help me diagnose the issue so I can do the repairs myself. I do not know what to look for in terms of whether or not I need a new touch screen all together or a new digitizer?
HELP!
Bu iyi bir soru mu?
Puan 10
8 Yorum
This question was migrated from http://meta.ifixit.com/Answers.
tarafından
I got a new screen for my nexus 5 and it turns on but it doesn't respond to any tap the other cracked screen the was in before worked fine PLEASE HELP
tarafından
I had the same problem for a while. Then I took my phone back apart again and reconnect all my connections and my touchscreen work. Give it a try.
tarafından
Jim Hal what do you mean reconnect all the connections?
tarafından
I removed and reconnect the connections of LCD & Touch Screen, but no progress...
tarafından
3 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
What you would need to do is follow the guide (link below) in order to get it open then find where the digitize cable plugs into the board. Look for corrosion and clean it off with isopropyl alcohol and a toothbrush. Let it dry and turn it back on to see if its working again. If not the only other step is to plug in a new working screen and see if it is a problem with your current screen or if there is board damage causing the issue.
Here is the tear down link to get inside: Nexus 5 Teardown
Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Here are the most professional tips about how to tell which Screen part you need for the Nexus 5:
LCD Only: If the image under the glass is broken and the touch screen is NOT then you only need a Nexus 5 LCD screen.
Digitizer Screen Only: If the top touch panel or aka glass top is cracked or broken but the image under it is fine, then you only need the Replacement Digitizer Screen for Nexus 5.
Complete Screen with Touch Panel and LCD: If the top touch panel for is broken and the LCD image is either black liquid or cracked you need a complete Nexus 5 Digitizer and LCD Screen Assembly.
The Nexus 5 replacement parts are for your reference.
Puan 2
Yorum Ekle
As others mentioned you need to replace the LCD Screen and Digitizer which come as an assembly. I would not recommend trying to replace one without the other.
TIP: If you just need to access the phone. You can connect a regular USB mouse with an OTG cable.
Also if you have the opposite problem (where the touchscreen works, but you can see it), you can use a SlimPort to HDMI adapter to see the screen on a monitor. I don't think you can use both an OTG and SlimPort at the same time.
Puan 0
1 Yorum:
I am using nexus 5 and I am not able to add whatsapp emoticons for the past 2 weeks. Now I did a factory data reset and even then, I am facing the same issue. On testing it using an app called "Screen Touch Test" the left side vertical touch region is completely blank without any dots and I assume the problem lies there. Any possible solution for this?
tarafından
Yorum Ekle
There is no option to replace just the digitizer on the nexus 5. Full frame must be replaced.
Puan 0
Yorum Ekle
I worked around the problem on my Nexus5 which had gotten wet and the Touch Screen function stopped working. Screen was not damaged, but horizontal lines on lower part makes it hard to read some things unless phone is rotated.
I purchased a micro USB OTG (On-the-go) cable from Fry's electronics for 4.99 and connected it to my phone USB/charging port with a old computer USB mouse connected. I was able to use it to Unlock my phone using the mouse, and go thru settings to disable the screen lock, then launch my apps to export my important files, and to then use USB cable and email file transfers to save the data.
I will next try to repair the Nexus5 phone by replacing the main board, and sell it used. I had already replaced my phone with a Nexus 5X, but was so unhappy with the poor memory and other problems of the 5X, I ordered 6.
Note: When the USB mouse is connected, battery usage is high, and there doesn't appear to be an easy way to charge and use the USB mouse at the same time.
Puan 0
Yorum Ekle
I had this issue, contacted google and they made me wipe out my phone to factory reset (DO NOT DO THIS), that didn't help. and after trying the fridge trick (Yes, I tried that too) was still non responsive.
What worked for me was: Wipe the cache partition (not the data), in recovery mode choose "wipe cache partition" and then reboot again, that worked for me. Hopefully this helps someone else.
Puan 0
Yorum Ekle
Had the same issue.. my display was a bit loose, so i decided to reglue it, after that process was done, touchscreen stopped working. After a bit of trying i figured out that it in my case it was the speaker! It somehow pushes from the backside. Didnt find out why though.
I removed it now it works all exept that i have no music anymore (phonecalls still work)
Maybe to someone it could be useful
Removing the speaker is very easily done. Removing the backcover takes a bit of time.
Puan 0
Yorum Ekle
I managed to resurrect my phone with a blow drier. Didn’t even open the case, just point it to the earphone jack (at the top of the cellphone) for 3 to 5 minutes, then reboot it (holding firmly on the power button), and it worked. I assume some water got in somehow. Hope this helps someone.
Puan 0
Yorum Ekle
Yanıtını ekle
Andrea Beaulieu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 71,255
