Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
REPLACE BATTERY NOW condition
hi,
I was using my macbook without the AC cable, running by its battery which has no any draining issue before. After I got 4% battery, I connected the cable but it says REPLACE BATTERY NOW. as I said, the battery was perfect with its performance before this and I haven't any trouble before. When I disconnect the AC cable, it goes off.
My macbook like a new and I don't use it much because I have iMac.
What should I do please!
Bu iyi bir soru mu?
Puan 0
1 Yorum
Did they end up replacing your battery at no expense to you? I would imagine they did. Please post a follow up. Thanks!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I could see an older model needing a new batt but a early '13 model shouldn't need it for at least 3 yrs.
Given the age of your system I would recommend going to Apple to have it repaired under Warranty ASAP as your time is running out (1 year without an extended Apple Care warranty).
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
abdullah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 477
