Ana içeriğe geç
Model A1419 / 2013 sonu / 3,2 ve 3,4 GHz Core i5 veya 3,5 GHz Core i7 İşlemci, Kimlik iMac14,2
screen hinge loose tilts
Is possible to tighten the iMac screen hinge without completely dismantling the computer. some claim a plastic card pushed in above hinge with release a clip allowing asscess to torx screws ?
Bu iyi bir soru mu?
Puan 5
2 Yorum
Any news on this?
tarafından Paylaş
I made a fix for this. www.themachack.com
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Simple solution: A rubber crutch tip placed between the monitor and the stand holds the monitor position securely and can be very easily adjusted in about 5 seconds. Cost: $0.29.
Bu yanıt yardımcı oldu mu?
Puan 6
3 Yorum:
Simple fix: A rubber crutch tip to support the screen is infinitely adjustable. Mine has been in place at least six months with absolutely no problem.
tarafından Paylaş
Yep,worked a treat
THANKS
tarafından Paylaş
What is a rubber crutch tip? Is it the piece that goes at the bottom of the pole of crutches? I’m trying to imagine how that would work.
tarafından Paylaş
Yorum Ekle
The newer iMacs have a newer foot design.
Your idea of a plastic card was the means to gain access to the foot screws to replace it for a VESA mount on the early '12 and older units. Sorry won't work here.
Here's some background: iMac 27" stand removal.
Given the age of your system I would try going to Apple for repairs.
Puan 2
Yorum Ekle
Yanıtını ekle
scoot sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 68
Her zaman: 15,364
