Ana içeriğe geç
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Soru Tümünü görüntüle
Sleep light comes on, no chime no boot.
Hi there.
My MacBook shut down recently doing an iTunes update and did restart but not boot.
I ran AHT and it said this disc cannot be used with this Mac but it is the correct disc that came with the machine.
I did a PMU reset , and it shut down on the second chime and would not boot. No chime no post. The sleep light comes on and stays on, until I power off.
I can hear optical disc activity and nothing happens.
I have tried removing the ram and reinstalling it. And this does not work.
Holding the power button for 20 seconds without battery and power does nothing.
Any ideas? Thanks so much.
Update
Yes , in my case it was a failed GPU. Once reworked / replaced it came back to life.
Bu iyi bir soru mu?
Puan 0
3 Yorum
Did you ever have a solution with this problem?
tarafından
So you replaced the entire Logic board?
tarafından
Yes , removed and replaced GPU with a rework station.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a link to a troubleshooting guide from Apple. Hope it helps--if not let us know. Ralph
http://support.apple.com/kb/TS1367
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Great thanks. Will take a look.
tarafından
Yorum Ekle
Whenever I have had these symptoms with a MacBook it usually had something to do with flaky RAM or one of the RAM slots went bad (soldering) or liquid damage in the past, or dust in the slots obstructing the contacts when RAM is inserted... It could definitly be something completely different! But I might try insterting one ram stick in the lower slot then trying to power it up, then with the same stick try the top slot, and if this doesnt work try the same thing with the other stick of ram... If none of that makes it boot up properly then you just used the process of elimination to verify that the problem is not the ram sticks or the slots.
Hope this helps!
Puan 1
Yorum Ekle
Yanıtını ekle
markduff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 3,231
