Ana içeriğe geç
Ekim 2011'de piyasaya sürüldü. Profesyonel sporcular, spor meraklıları ve sıkı takipçiler tarafından kullanılan GoPro'nun ikinci nesil dış mekan video kamerası.
Internal battery not powering unit
The camera works fine when connected to a backpack battery or is being powered thru USB. But when it's just the battery installed in the camera, it receives no power - regardless of which battery is installed.
Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Ian, does this "regardless of which battery is installed." mean you tried a new battery? Have you checked the make sure the contacts are properly lined up?
tarafından
Yes. I tried swapping the battery in the GoPro with the one in the backpack (the backpack, when installed, powers the unit) and it did not power up. The three battery contacts in the camera do not seem to be corroded or misaligned in any way. They line up fine with the slots in the battery.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
My first guess is the battery connector is either damaged or has become slightly unsoldered. I would touch it up with some new solder first. If its not that then its probably circuitry related to whatever switches from battery power to ac power. Maybe a loose connection there, but re-soldering that is flirting with disaster if you ask me. I dunno maybe find one with a broken lens and replace the motherboard if you are feeling up to it, good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,427
