Ana içeriğe geç
Touchscreen smartphone by LG released in 2011.
How to replace the micro USB port on LG G2X?
I have an LG G2X smartphone which worked perfectly until not long ago. The micro USB port with which it is charged with would respond less and less each time I would charge it. It got to the point where I would not be able to charge it whatsoever. I have searched up different means to repair it but they all ended in failure. I now believe that the only way to out an end to this problem is to replace the port entirely.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Thomas Varas, you could either try to solder a micros USB like this to the cable, or replace the lower FPCB. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Thomas Varas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,330
