No power, popping sound from speaker.
Hey there everyone. I'm having a problem that has plagued the 3DS, the "my system if turning off and making a popping sound after 3 seconds". I have already tried reseating all of the ribbon cables and that hasn't fixed it. All of the information I can seem to find says that is the main problem. Is there any other problem that could cause these symptoms? Thanks for the help!
Bu iyi bir soru mu?
3 Yorum
This occurred with a red 3DS of mine after someone bent the screen back too far and disconnected the tabs holding the screens together, also causing heavy LCD damage in the process. The system worked until the lid was closed, then this problem began happening permanently. I cannot open the 3DS, the screws are severely stripped. There is so much black ink on the inside of the screen that it looks like someone splatted an inkwell on the screen, visible even when off. This covers nearly the entire screen.
Michael Deitz tarafından
@michaeld2 hi this has happened to me but on a 2ds. I think it had water damage
[deleted] tarafından
My mom slammed it on my door and turned it off. I came to check if it worked and that happened. I slammed it on the carpet.
I thought it was it not being charged enough (Even though my DS was fully charged) so I just assumed it was bricked.
ShinyLuxio 312 tarafından
