Ana içeriğe geç
Introducing the Dell XPS M1530, a sleek and powerful multimedia machine expertly balancing performance, design and unprecedented functionality.
11 Soru Tümünü görüntüle
My screen is cracked and working partially.
Can I replace my screen? It works partially but not where it was stepped on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Were an I get a screen
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
sure - why not?
the lcd is available in many online shops or ebay.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I really appreciate your response. I will do a little research and find one. Thanks,
Bill
tarafından
you're welcome
tarafından
Yorum Ekle
Replacing the LCD panel on a Dell laptop is not easy. There's a whole bunch of screws that have to be removed in order to replace the LCD. Be sure you shop around, because LCD panels for laptops can be expensive, and in some cases, can cost almost as much as the computer itself. I learned that the hard way when I spent $600 for a new LCD panel for my Inspiron 8600! (the system died soon after replacement). So depending on the age of your laptop, I wouldn't bother replacing the panel. Just purchase a new laptop, which would be much cheaper and you'll probably get more powerful hardware (don't spend less than $1,500, though). So my recommendation is to shop online for your LCD panel, or purchase a new laptop. I have a Vostro 1400, and already there's a yellow line going down the screen. I'm not going to get a new panel, since the laptop is over 3 years old. Good luck!!
Puan 0
Yorum Ekle
You cannot fix cracked screen, it has to be replaced.
Probably can find cheap on eBay.
Screen removal instructions published in service manuals for Dell laptops at Laptop Manuals Hub
Find your manual and follow the instructions.
Puan 0
Yorum Ekle
I ended up buying a screen locally and installing it. It wasn't the right one and it didn't work. I had to take it to a shop where I have had terrific support here in Houston called Computers and More. 10717 Gulf Freeway Houston Tx 77034. 713 941 5999. They changed the screen repalced the ballast for the backlight becasue it was humming and gave me back the incorrect screen. I was able to return the screen for a complete refund. Thanks for the suggestions. Bill
Puan 0
Yorum Ekle
Yes for sure you can and as it is cracked then there would be no option apart from replacing it. You can easily replace it by yourself if you are confident about your technical skills and order the new screen online the replace it by following the youtube tutorials.
Puan 0
Yorum Ekle
Yanıtını ekle
Bill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 5,451
